Idle Problem - Stall After Starting
140,000 MILES • 2.7L • V6 • 4WD • MANUAL
TGOHEEN
There have been two separate incidents that this happened. First, I went to a clothing store and returned to my car after about 10 minutes. When I started the car, it made it to around 1000rpms and then dropped all the way down until it stalled. It did this again on the second try. I then was able to give it gas right after starting and get out of the parking lot. A similar thing happened after getting a few gallons of gas. I haven't tried to solve the problem yet, as it usually isn't an issue. The only other thing I have noticed is a fluctuation in idle rpms while the car is in park and running (moves around from around 500-1000rpm). This only has occurred during the two times the car started and stalled.
Nov 7, 2014 at 10:31 AM
  • 31,937 POSTS
The idle control motor is probably starting to fail, have this cleaned and if this dose not help get it replaced.
Nov 13, 2014 at 8:26 PM
