Idle problem
100,000 MILES
JGUNDY11
  • 5 POSTS
I have a 98 toyato camry and it idles between 0 and 1 and sometimes it looses power when first starting to accelerate. And justi had a air mass flow sensor replaced .What could this be?
Apr 16, 2013 at 2:57 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first
Apr 16, 2013 at 11:52 PM
KHLOW2008
  • 41,812 POSTS
Are there any trouble codes?
Erratic idling is due to a fault with the idle control and cleaning the IAC and throttle body should help to stabilise the idling.
Apr 16, 2013 at 11:54 PM
JGUNDY11
  • 5 POSTS
Today i cleaned the throttle body and still.idles
Apr 17, 2013 at 2:03 PM
KHLOW2008
  • 41,812 POSTS
Did you clean the IAC as well and check it for sticking?
Were the spark plugs checked?
Apr 18, 2013 at 12:25 AM
JGUNDY11
  • 5 POSTS
i got the trouble codes and they are po 130/ po 106 / po 133/ po 773
May 8, 2013 at 12:45 AM
HMAC300
  • 48,601 POSTS
check your O2sensorand check for a vacuum leak your map sensor is giving a reading too but it may be a vacuum leak causing the problem.
May 8, 2013 at 12:49 AM
JGUNDY11
  • 5 POSTS
Wheres the o2 sensor and which vacuum
May 8, 2013 at 3:04 AM
HMAC300
  • 48,601 POSTS
take this to a pro and save your self some money, if you don't know what you are looking for
May 8, 2013 at 3:16 AM
JGUNDY11
  • 5 POSTS
Just take it to one tell em about the idlying and hand em the codes
May 8, 2013 at 3:36 AM
KHLOW2008
  • 41,812 POSTS
Check the MAP sensor vacuum line first. It can cause problems with erratic idling and the O2 sensor codes. The other code is the lockup clutch solenoid for the transmission. It could be faulty or the wiring circuit has a fault.
May 8, 2013 at 3:39 AM
