Also, I have seen a bad engine coolant temperature sensor cause the same problem so I would unplug it to see if the problem changes, Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with.
Images (Click to enlarge)
May 16, 2024 at 5:07 AM
JOHN JACOBSON
MEMBER
The rest of the day starts and runs normally. Throttle body was cleaned and PCV sensor replaced, no help.
Nov 18, 2024 at 3:15 AM
(Merged)
✓Experienced Mechanic
Let's run the codes first to see if any are stored, this guide will help. Also, I have seen a bad engine coolant sensor cause this issue.
First start in the morning, revs to 2,000 RPMs then drops and burps a few times and shuts off. After I get it going it runs great the rest of the day. Have changed many parts and sensors but to no avail. Only happens with the first start of the day.
(Merged)
What parts have you replaced? Did you run the codes?
JOHN JACOBSON
MEMBER
2 mechanics have run the codes, and these parts have been replaced. PCV and EGR valves, camshaft pos. sensor, mass air flow sensor, fuel pump and filter, throttle body cleaned, fuel pressure regulator. Still the same problem has been going on for a long time.
Nov 18, 2024 at 4:36 AM
I have seen the engine coolant sensor cause this issue and leave no codes. Here is the location of the sensor so you can swap it out. Check out the images (below). Please let us know what happens.
