Idle is too high?
128,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
ALBERT DIAZ
Start truck warm up, drive and Idle does not come down, runs great it just Idles too high.
Sep 15, 2023 at 12:48 PM
  • 110,248 POSTS
The first thing I would recommend is to clean the throttle body bore. There could be dirt or corrosion preventing the throttle plate from fully closing.
Here is a link that explains how that is done:
Also, there is an idle air control valve (IAC) mounted on the throttle body. Its function is to control the idle speed. The pintel on the IAC may not be working properly and allowing too much air to enter the engine. I attached a pic below of its location.
You also should remove the IAC and inspect/service it.
Here is a link that explains how to do it.:
https://www.2carpros.com/articles/idle-air-control-valve-service
Also, take a look through this link. You may find it helpful.
https://www.2carpros.com/articles/engine-idles-too-high
Let me know what you find or if you have questions.
See pic below.
Sep 15, 2023 at 3:46 PM
