Idle high and dips low?
188,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
PAGE0210
  • 20 POSTS
The rpm dip low constantly and the car acts as if it wants to stall. Rough uphill and definitely difficult to get it to highway speeds.
What I've done
- changed out both catalytic converters and the downstream 02 sensor. The upstream 02 sensor they ordered was wrong so it's disconnected but the problem was before this.
- Checked for air leaks at the intake and manifold. Manifold has a small crack but I don't think that would cause this?
Any ideas would help out significantly. Thank you guys for your time you are awesome!
Feb 27, 2026 at 5:05 AM
  • 55,711 POSTS
Your are welcome, we try to help the best we can, the line "Manifold has a small crack" can be the problem, this condition is indicative of the vacuum leak, can you upload an image of the crack you see? Also, I would remove the throttle body and service it. Here are two guides to go over to help fix the problem.
https://www.2carpros.com/articles/engine-idles-too-high
and
Please go over these guides and get back to us. Ken
Feb 28, 2026 at 2:05 AM
