idle goes down and shuts off when A/C is turned on and when transmission is shifted into gear
175,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
VINDEUS_071118
The engine starts well, no troubles appeared on the scanner after we replaced throttle position sensor, intake air control valve. But still the engine finds it hard on idling when it has load such as A/C and when shifted. instead of idling up it goes down. the engine is blow by.
Sep 4, 2019 at 5:55 PM
  • 110,248 POSTS
Welcome to 2CarPros.
When a load is placed on the engine such as the ac, there is what is called a stepper motor or idle air control (IAC) motor that is to adjust for the load to prevent issues. If that doesn't respond, the added load can cause the engine to stall.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Also, have you checked to make sure there are no engine vacuum leaks? That can cause a rough idle and stalling as well.
You mentioned the intake air control valve. Did you mean the idle air control valve? If so, did you check to see if there was any dirt, carbon or corrosion in the throttle body where it mounts?
https://www.2carpros.com/articles/idle-air-control-valve-service
One last thing. Have you checked the throttle body to make sure there isn't a build up of carbon or dirt in it?
Let me know if anything here helps or if you have other questions.
Sep 6, 2019 at 1:04 PM
