idle drops and car stalls when engine warms up
200,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
LEON NGUYEN
The car starts perfectly on cold crank and then once the engine warms up, the idle drops to less than 500 rpm and the car just stalls. If I apply gas, the idle picks and the car runs fine. Please help
Mar 13, 2017 at 3:59 AM
  • 55,770 POSTS
Hi Leon,
It sounds like you have a vacuum leak or an IAC motor that is stuck and needs to be cleaned, here is a couple of guides that will help you get the problem fixed.
https://www.2carpros.com/articles/stall-at-idle
and
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Mar 15, 2017 at 5:49 AM
LEON NGUYEN
Thank you for the input Ken. I will definitely try your ideas and will post a respond as soon as I'm done.
Mar 15, 2017 at 2:35 PM
