Check engine light is on and misfire on cylinder two
140,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
WELLS L
Car does not smoke or use oil. Car runs great above 1,000 RPMs. Have misfire on cylinder 2 below 1,000 RPMs. Check engine light is on. I have replaced plugs and coils. Replaced fuel injector for cylinder 2. What could be my problem?
Jul 11, 2021 at 2:03 AM
Good evening,
I would service the throttle body. If there is carbon build-up, it will block the passages for air to pass into the engine
https://www.2carpros.com/articles/how-a-throttle-body-works
I attached a guide for you for the procedure.
Jul 11, 2021 at 10:06 AM
WELLS L
I have put seafoam through the throttle body vacuum line . There is no carbon on valves and throttle body is clean. I am sorry I didn’t mention that before. Is there anything else I can try?
Jul 11, 2021 at 10:24 AM
This could be a vacuum leak. Look around the intake for any hoses that may be cracked or off. If you have a leak, it will run poorly at idle.
If you have a scan tool, check the long-term trim readings to see what the percentage is at idle. It should be close to 0 on the monitor.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Jul 12, 2021 at 7:56 AM
