Does this car have an idle air control valve ?
103,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NATALIE REDDEN
does this car have one and where is it located?
Feb 19, 2021 at 6:47 AM
You vehicle does not have one as the PCM controls the idle through the throttle body. I attached the info on this plus how to clean it and relearn the throttle if this is what you are looking for.
Lastly I attached below the process on how to replace the throttle body as well. Let us know if you are looking for some different info. Thanks
Feb 20, 2021 at 7:58 AM
