idle
132,100 MILES
JJKENJO
When im sitting at a redlight the truck idles at 300 rpm when I touch the gas it will die. I have replaced throttle position sensor, mass air flow sensor. Found no vacuum leaks no service engine light. What could cause the truck to do this
Apr 27, 2013 at 8:18 AM
  • 31,937 POSTS
Base idle is way to low, have you checked the IAC as yet? that is the idle control motor.
Apr 27, 2013 at 9:51 AM
JJKENJO
It's made into the throttle body my truck has a 5.3 v8 t model no egr valve
Apr 27, 2013 at 11:37 AM
  • 31,937 POSTS
Have you checked it yet?
Apr 27, 2013 at 5:35 PM
JJKENJO
Its good checked the fuel pressure it is at 30 psi
Apr 28, 2013 at 2:16 AM
