car vibrates quite a bit?
99,650 MILES • 2.0L • 4 CYL • AUTOMATIC
CHRIS GUERRERO
When i start the car the car vibrates quite a bit and my question is if i need to change out the sppark plugs because when i drive it doesnt accelerate that quick.
Aug 22, 2025 at 7:50 AM
MECHTRIX
  • 586 POSTS
Yes if you dont have a check engine light on ..thats a good idea and check the air filter to wont hurt can only help good luck
Aug 22, 2025 at 10:08 AM
  • 55,710 POSTS
This is usually because the engine is misfiring. Do you have a check engine light on? If so this guide can help us get the codes which will tell us what cylinder is having the issue.
This guide can help as well
Please go over these guides and get back to us.
Aug 24, 2025 at 4:28 AM
