idle fluctuates up and down when in gear and stopped
80,000 MILES • 6.6L • V8 • AUTOMATIC
RONALD TROXELL
  • 5 POSTS
My Lincoln drives like new until I stop for red light or stop sign. Then the idle starts up and down up and down when in gear. Much worse when in neutral.
Oct 24, 2016 at 11:08 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner. also, check for vacuum leaks like a cracked hose or one off etc.
Oct 24, 2016 at 11:25 PM
RONALD TROXELL
  • 5 POSTS
Thanks. I do not know what the IAC hole is or where it is located?
Oct 25, 2016 at 6:44 AM
HMAC300
  • 48,601 POSTS
it's the idle air control motor but it's a n oblong hole in throttle body you'll see it
Oct 25, 2016 at 9:29 AM
