Rough idle when in park
2010 FORD F-150
154,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ADAM5080
Rough idle when in park if I shut the truck off it goes away.
Jan 22, 2019 at 8:49 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny
Having this issue has it set the check engine light? If so that means trouble codes are stored in the vehicles computer.If you don't have any access to a code reader your local auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved.
Once you can provide us with the trouble codes (if any) or let us know if there is no check engine light we would be happy to address the problem.Hope this helps and thanks for using 2CarPros.
Danny-
Jan 22, 2019 at 6:45 PM
ADAM5080
There are no codes
Jan 22, 2019 at 6:47 PM
DANNY L
  • 5,648 POSTS
Hello again
Have you tested or inspected the throttle position sensor or throttle body? I've attached a picture below.Hope this helps and let me know.Thanks again for using 2CarPros.
Danny-
Jan 24, 2019 at 4:58 PM
