idk if i want this car
134,000 MILES • 2.0L • 4 CYL • TURBO • FWD • MANUAL
TURBOLOVE98
On craig list saw a 98 gst eclipse the guy bought it froma kid said it was sputtering n wouldnt run right then the kid stole the ecm and sterio i have no idea if the wiring is good or not my main concern is the engine it turns over slowly and i cant do a compression check is tht wierd it turning over slowly while being jumped?
Oct 10, 2014 at 2:39 PM
  • 31,937 POSTS
Try bolting in a good battery or get the existing battery charged and check all battery terminals are clean and tight, jumping with cheap leads can be a problem, so if you need to do a jump start make sure that the connections are good and tight.
Oct 10, 2014 at 11:33 PM
