firing order - cylinder number one location needed?
85,000 MILES • 3.9L • 6 CYL • 4WD • AUTOMATIC
KJGCT1
I have a misfire on cylinder number one. Which cylinder is number one, and what size is the spark plug socket?
Feb 3, 2020 at 2:34 AM
CARADIODOC
  • 34,414 POSTS
Driver's side front. The 3.9L is a version of the 318 c.i with two cylinders chopped off. In 2005, the engine choices were 3.7L or 4.7L. Chrysler's numbering system is 1, 3, 5, front to rear on the driver's side, and 2, 4, 6, front to rear on the passenger side.
Most likely the spark plug socket you need is 5/8". Older engines used 13/16" spark plugs.
For others researching this topic, this article may be of help:
https://www.2carpros.com/articles/how-to-change-spark-plugs
This video shows this job being done on a Caravan:
https://youtu.be/CE7bM8_j4Zg
Feb 3, 2020 at 5:49 AM
LESMORE
what is the firing order for a 2003 Dodge dakota v6 on the distributor?
Apr 2, 2021 at 3:03 AM (Merged)
JDL
  • 16,098 POSTS
Here is the firing order for your car in the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
MICHAEL GUIDRY
Spark plug wiring from plugs to distributer on the vehicle listed above slt model.
Apr 2, 2021 at 3:05 AM (Merged)
SEVAG P
  • 405 POSTS
hi,
fig 1 is the routing of the ignition wires and the fig2 procedure how to install the distributor at correct timing, at the fig 2 you can see a notch on the distributor, rotor must face toward the notch, that means spark plug wire that located at the notch is the cylinder 1 wire. also cylinder 1 must be at TDC compression.
let me know if you need more help.
HE110K1TTY
i need to know the firing order for my truck it has a v6 magnum. 1 more question my truck has no power what so ever it is bucking really bad and my check engine light just starting flashing. if you could help me out I'd be greatly appreciated. thanks
BMRFIXIT
  • 19,053 POSTS
flashing check engine light is engine misfiring check it for tune up
https://images.2carpros.com/forum/automotive_pictures/99387_dakotaa_1.jpg
HOLLADAYTAMMY
Need fireing order for 318 engine.
  • 75,988 POSTS
Here you go
https://images.2carpros.com/forum/automotive_pictures/12900_fo_104.jpg
MICHAEL 1956
Not wired back to distributor correctly .Where is no # on the distributor cap?
RIVERMIKERAT
  • 6,106 POSTS
There's a notch in the body of the distributor that lines up with a corresponding tab on the bottom of the cap.
LASABABRAVA
excuse me i was doing the tune up on a dodge dakota 1994 i pulled out all the wires and i canot put them back together i have no idea how the order is the truck keeps turning of i have no idea how to put it back please help me explain me please..
Apr 2, 2021 at 3:06 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
firing order dodge V8 5.2L engine
https://images.2carpros.com/forum/automotive_pictures/99387_dode_52_1.jpg
AUTOMAN40
I accidently got my plug wires crossed when changing them. Can you tell me what the firing order is, where number one cylinder is, and where number one location on distributor is?
  • 75,988 POSTS
There you go have a nice day
https://images.2carpros.com/forum/automotive_pictures/12900_dodge_fo_1.jpg
CHEYENNE5199
distrubuter what is firing order? 1992 Dodge Dakota 318 magnum
  • 110,248 POSTS
Hi: Here is the diagram with the fireing order.
https://images.2carpros.com/forum/automotive_pictures/249084_firing_order_1.jpg
I hope this helps. Let me know if you have other questions. Joe
DGR1941
I accidently mixed up the wiring for the wires to the distributor cap. what is the order and where do you put the first wire? Maybe you have a diagram i could look at?
Thanks
IMPALASS
  • 3,112 POSTS
Hello Here is the info you requested Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://images.2carpros.com/forum/automotive_pictures/248015_Firing_Order_1.gif
MINWELLA29
What is the firing order for this vehichle
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_fo_159.jpg
