Identify an oil leak?
45,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
STARBUCK106
I've got an oil leak from the engine. There's a belt driven component that's covered in oil, but I can't identify it. I did put a dye in the oil, so I know it's coming from the engine. If I could identify the component, it might help me identify where the leak is coming from. It's not a head gasket leak. Looking at the engine from the pax side, it's under the overhead cam drive belt cover on the left side or rear most cam. I think it's the 2,4, and 6 cylinder head.
Jun 27, 2023 at 5:33 AM
  • 110,246 POSTS
Is there a chance you could upload a picture of where you see the oil? That would help me identify the possible cause.
Next, I attached an exploded view of the engine below. Do you see where the leak may be located in that picture?
See pic below.
Jun 27, 2023 at 1:19 PM
