Icy billet bracket kit?
1994 GMC C1500
258,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CODYMAN363
I am following your LM7 build on a 5.3 L and I wanted to make sure that the ICT billet bracket kit you used for the alternator and water pump set up won’t prevent me from adding on A/C and other accessories. This will be my daily driver so I would like to have all accessories available just like if it was stock. Thank you.
Jan 22, 2023 at 4:29 AM
  • 110,236 POSTS
I will forward your question to Ryan. If you don't hear from him in a day or two, let me know. He is usually very responsive to these questions.
Jan 22, 2023 at 10:46 AM
RYAN L
  • 272 POSTS
Hey there!
Thanks so much for watching the series!
So, no, our set up for accessory drive will not work for your set up. If you want it to be stock, I would put the stock mounts and tensioners on if you still have them. However, if you don't you can check out this page to give you what you need for your situation. https://www.ictbillet.com/ls-parts/ls-accessory-brackets/truck-camaro-ls-accessory-brackets.html
Just make sure you have the truck style damper and water pump like we have.
You can also call ICT Billet's help line for precise info on what you specifically need if it is not clear 316-300-0833.
Thank you for using 2CarPros!
Jan 23, 2023 at 6:26 AM
