Ice built up on intercooler?
66,400 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
DEGSGREG
  • 13 POSTS
Please help me here, I am sick and tired of these GM dealerships where i live telling people stuff has to be replaced in your vehicle when there is no problem with it. If an intercooler has ice buildup on it, does it have to be replaced? Also, if there is a problem with the intercooler, will it throw out a check engine code? I have the car listed above Premier.
Jan 17, 2024 at 2:37 AM
  • 110,248 POSTS
Freezing up is usually the result of moisture in the air that enters the intercooler system.
Please keep in mind, I have no idea where you are located, the temperatures where you are, or how the vehicle is used. So, bear with me.
There are a few things that can cause this to happen. First, it could be the intercooler. Also, if the vehicle is left to idle for an excessive amount of time, dirty intercooler, insulation issues, and the list goes on.
What that in mind, was there a reason given that explained why it needed replaced?
Jan 17, 2024 at 9:46 AM
DEGSGREG
  • 13 POSTS
I live in regina, SK, all the service advisor told me , after he check for , the codes, that the intercooler has ice buildup on it, and to replace it, he wrote down both code s for me, when i got home ,i check out what those code mean., both of them were showing ,number 2 oxygen sensor is bad, i never had that problem before with my car, most of the driving i do is city driving, the day before the car started acting up ,i was out on the ring road, i maybe put 8 miles on the car, going from one dealer ship to the next one. It was not very cold that day, minus 15 Celsius. The car was running fine, my car is park outside all day, 2 days later when i went out to use it, the check engine light came on, right when i started it. It is solid, not flashing. In the city the car was running good, but i wanted to see if it would act up at highway speed. So once i got out on the highway, i went maybe about a mile, the car was running fine, all at once the power drop right down, it would go about 80 clicks only, i could tell it wasn't shifting properly ,after about 5 minutes , when it started losing power, the dash monitor was showing ,engine power is reduce, as soon as i could turn off from the direction i was going, to go back into the city, i drove about a mile and a half, then it started running like it should, when i got back into the city i went to put more gas in it, I filled it right up, then went to a restaurant ,i was in there only for a half a hour, come back out, i wanted to take it out on the highway again , to see if it would keep running normally ,in the city it was alright, the minute i get out on the highway again, it lost power , and the dash monitor was showing the same message again, the questions i have, is will they trough a code if there is a problem with the inter cooler, and also the turbo, or the transmission. I have been told it is a common problem with the Chevy Cruze intercoolers, icing up, i had it check again if any other codes have come up. Only the 2 from before showed up.
Jan 17, 2024 at 11:39 AM
BORIS K
  • 836 POSTS
I would suggest calling your nearest Chevrolet dealer.
There is a service solution for your issue, also a TSB 22-NA-007.
https://static.nhtsa.gov/odi/tsbs/2022/MC-10209471-0001.pdf
Also see article in GM authority:
https://gmauthority.com/blog/2023/01/gm-releases-fix-for-chevy-equinox-malibu-trax-and-cruze-charge-air-cooler-icing/
The hazards: If ice or sludge accumulates in the vehicle CAC or CCV system, it may result in a number of engine issues, including performance loss, an oil leak, incorrect boost levels, or various Diagnostic Trouble Codes (DTCs).
The fix: to address this issue, a GM technician will install a TCV thermal wrap on the engine and, if needed, reprogram the Engine Control Module (ECM). A new turbocharger wastegate regulator solenoid valve may also be installed. GM technicians are instructed to remove the turbocharger wastegate regulator solenoid valve, test, apply the thermal wrap, and either recalibrate of verify the ECM programming, as well as clear any possible DTCs that may have triggered.
Cheers, Boris
Jan 17, 2024 at 5:45 PM
DEGSGREG
  • 13 POSTS
The only codes that are showing , have to do with , the number 2 oxygen sensor, my questions, were very simple, all i want to know is if there is ice buildup on the intercooler, or if there is a problem with it , if a check engine light code, will show up for it, and i was asking the same question about the turbo, if it went bad, if a code will show, for it, the reason i want to know about this, after the gm service advisor , check it to see what codes were showing , i as him what has to be done, he told me , there is ice buildup on the intercooler, and when that happens, they have to be replaced, of what i have seen , on the Cruze forum , that is only a problem, that occurs, with highway driving, witch i wasn't doing. At the time, also on the forum, it states that people had the intercooler replaced, and it did not resolve the problem.
Jan 18, 2024 at 3:00 AM
  • 55,673 POSTS
Do you notice any problems or just ice on the intercooler? If it is the latter ice buildup is normal in cold weather with humidity, here is information that I found on the subject:
Ice buildup on an intercooler can occur in cold environments, especially when there's high humidity. It usually happens due to the cooling effect of the air passing through the intercooler and condensing moisture which then freezes.
Removal: Simply having ice on the intercooler doesn't necessarily mean it needs to be replaced. If ice buildup is occasional and caused by environmental conditions, removing the ice and ensuring that the intercooler is dry can often resolve the issue.
Please let us know if you need any more help.
Jan 18, 2024 at 4:07 AM
DEGSGREG
  • 13 POSTS
Greg, yes ken, i am living in regina, Saskatchewan, we do get very cold spells here at times, but my understanding is, that it happens, with highway driving mostly, not with city driving, as i stated in my first post on here, last week , i was out on the ring road, but that day, we had normal temps, for here. i have had this car for a bit over 5 years now, and drove it out on the highway, in very cold weather, and never had a problem with it, until now.
Jan 18, 2024 at 4:43 AM
DEGSGREG
  • 13 POSTS
I have been told buy one of the mechanics to go out and look to see if there is ice buildup on the intercooler. I took a flash light out with me, first i shone it though one of the opening on the upper grill to see if there was ice buildup showing on the air conditioner cooler, or frost on it, the is no ice on it or frost at all on it, or wet spots on it, it is completely dry. Just like it would look in the summer. Then i bent over, to shine the flashlight in the opening on the lower bumper cover acted like i expected, even before doing this. There was no ice buildup on it or frost, or wet spots on it also. Again, it looked like it would be in the summer time. The codes that show are p2277/ and p2099. As i said before, i checked what those codes are for, it shows in the code lookup manual i have, that that has to do with the number 2 oxygen sensor, that it went bad.
Jan 18, 2024 at 1:22 PM
  • 55,673 POSTS
So, are you having any other problems besides the ice on the intercooler? It may be normal, and the slight change can be the turbo wearing out. You might want to remove the either the inlet to outlet tube and check the turbo endplay.
https://www.2carpros.com/articles/how-turbo-chargers-work
Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Jan 19, 2024 at 1:49 AM
DEGSGREG
  • 13 POSTS
I finely look last night, there is no ice buildup or even frost buildup, or wet spots showing on it, . Ni new from before, there wouldn't be ice buildup. Because of not doing any highway driving, at all. My car exterior is kept very clean the inter cooler, transmission cooler and radiator still look like they did from day one. When the car was new, there isn't even any dust or dirt built up on that stuff. also, i don't abuse my vehicle.
Jan 19, 2024 at 3:46 AM
STEVE W.
  • 15,397 POSTS
I think a key word is missing here. The ice doesn't build up on the exterior of the intercooler (well it can but it won't do much) where the issue is is inside intercooler. Moist air comes in, goes through the filter into the turbo. Then it goes to the CAC. The airflow in very cold weather causes that air to cool very fast and the water in it starts to form ice in the intercooler passages. That leads to reduced airflow and you get codes representing that.
Usually those codes would be what you have, low airflow causing an overly rich mixture.
However those codes you listed don't show up in the code tables for that car. They are valid codes however both relating to a fuel rich exhaust. I would probably check the wiring going to them for damage, been seeing rodent damage a lot in cold temperatures. Also could you verify that those are the codes you have? The P2277 and P2099 codes? Thank you.
Jan 19, 2024 at 3:32 PM
