IAC wiring diagram needed
180,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BOBBY ROE II
Went to clean the IAC and discover there is no wiring harness pigtail, and I can't find where to hardware the new pigtail. please help me!
Oct 13, 2021 at 11:02 PM
Good morning,
I attached the wiring diagram of the IAC for you below. It shows the color wires for the solenoid.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
I also attached the connector available from Rock Auto for the end of the harness.
Let me know if you have any other questions.
Oct 13, 2021 at 11:41 PM
BOBBY ROE II
Thanks so much for the quick reply the diagram saved me a lot of time that I just don't have... found the correct wires, spliced in and now it's good to go. Once again I appreciate it, worked out great!
Oct 14, 2021 at 12:19 AM
You are welcome.
Always glad to help.
Let us know if you have any other questions.
Oct 14, 2021 at 2:02 AM
