IAC Valve wiring diagram needed?
230,000 MILES
IBRAH1098IB
want to know which color goes to each pin. It's a 3 pin IAC.
Feb 13, 2023 at 4:45 PM
  • 55,554 POSTS
Yes, the wiring diagrams show three wires to the IAC motor. Here are the wiring diagrams which are included in the engine wiring. I also included a guide to help you test the connections as well.
Please check out the images below and let me know if you need anything else.
Feb 14, 2023 at 3:58 AM
  • 110,246 POSTS
I tried finding a pic that showed specifics but was unable. So, I had to do it this way.
If you look at pic 1, the schematic indicates the wire color and pin it goes to. Pic 2 is the connector view. I numbered the connectors.
joe
Feb 14, 2023 at 4:06 AM
