IAC valve relearn
200,300 MILES • 2.3L • V8 • 4WD • AUTOMATIC
ANGEL0324
  • 26 POSTS
What's the IAC vavle calibration or how do i perform a relearn program for it?
I have P0507 and i am sure that it is because I replaced this valve without any of this.
Jan 11, 2019 at 10:24 AM
STEVE W.
  • 15,394 POSTS
Welcome back.
Okay, P0507 - Idle speed higher than expected.
First remove the negative battery connection for about five minutes, this should clear the idle memory. Reconnect.
Start the engine and rev it to 1,500 rpm, then back to idle (500) then back to 1,500 and back to idle.
If you have the code return and the idle speed is high then verify that there are no vacuum leaks as they can also set this code.
Jan 11, 2019 at 11:13 AM
ANGEL0324
  • 26 POSTS
Okay, I'll try tomorrow morning and see what happens. thanks for your help.
Jan 11, 2019 at 11:27 AM
  • 55,649 POSTS
Please let us know.
Jan 14, 2019 at 4:52 AM
