I've got a Vauxhall vector design 150 I've been told that my clutch is on it's way out do I have to replace the dule mass fly wheel as well
2005 VAUXHALL VECTRA
120,000 MILES
WAYNE F
When I put the car into gear and go to pull away the car starting to not rev and seams to just slowly after a time cost along then it will spring back in to life and shoot off been told it's the
Mar 31, 2016 at 9:32 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
w ehave no info on this car as it's not in USA but make sure clutch is adjusted if it can be or hydraulics are working . but sounds like a bad clutch
Apr 1, 2016 at 7:10 AM
WAYNE F
Thank you I've solved the problem bye the way of cash at a garage and it was the clutch but I didn't need to replace the duel mass fly wheel as there is a new clutch design were I've been told that the fly wheel and clutch come's as one package and it's works out alot cheaper and more efficient and a saving of 200 pounds . But a big thank you from me for trying to help
Apr 1, 2016 at 9:34 AM
