Here is the top half of the Data Bus wiring diagram showing the two power locations for the DLC. Pin 16's fuse is in the fuse panel that is behind the left (driver side) lower kick panel, so down near where your left foot would be, you will most likely have to remove the kick panel, or there might be an access cover, I will look to see if there is a picture of it. But pin 16 provides power to most scan tools, but the grounds at pin 4 and 5 are required as well. When testing with a multimeter just don't spread the pins inside the DLC.
Sep 1, 2024 at 2:23 AM
