How to change the transmission oil?
100,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MITCH MORRIS
Hello, I need step by step instructions on how to change the transmission oil.
Thank you
May 23, 2021 at 10:00 PM
  • 55,616 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car with fluid type and capacity:
This video shows the job being done on a similar car but the process is the same:
https://youtu.be/FglBsUEOSEk
May 25, 2021 at 3:16 AM
