I want to do a engine swap
184,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
KOLEC94
  • 18 POSTS
I want to swap out the 2.2l 2200sfi motor that i want to swap for a motor with a bit more power but I don't know what would be easy to swap to.
was thinking a chevy 3500 turbocharged
Nov 24, 2015 at 3:31 AM
HMAC300
  • 48,601 POSTS
it won't fit stick with what you have or a 2.4 and that's about it. unless you want to spend cubic dollars and take one out of 2.0L turbo but that is a ton of work and cheaper to just buy something with more power.
Nov 24, 2015 at 4:40 AM
KOLEC94
  • 18 POSTS
How hard would it be to swap it to the 2.4L and would I have to swept the transmission to?
Nov 24, 2015 at 4:56 AM
HMAC300
  • 48,601 POSTS
a 2.4 is about the same size just motor mounts maybe and a different torque converter if it's balanced different.
Nov 24, 2015 at 5:00 AM
WRENCHTECH
  • 20,760 POSTS
Are we forgetting about the entire operating system here? Everything that operates that engine was engineered for the original engine. That means the computer and all the wiring the exhaust system, the cooling system and all the accessories that attach to the engine.
Nov 24, 2015 at 8:17 AM
KOLEC94
  • 18 POSTS
so should i just put a turbo on it and leave the rest alone
could i run no2 on it
Nov 25, 2015 at 2:30 AM
HMAC300
  • 48,601 POSTS
those motors were not really built for that kind of application but do what you want. you'll have to modify the computer as well and you'll still have a cavalier that really isn't worth that much it's a lot of money to spend as well as time to do it.
Nov 25, 2015 at 5:14 AM
