I have the vehicle listed above LE model. Electrical wise the remote start was installed. I also want to add fog lights. I've did a lot of research regarding fog light connectors. The majority indicated that it is pre-wired. The problem I'm running into is, I can't find the connectors. I've taken the liberty to physically install an after market kit, installed the multi-switch stalk with fog lights switch. I'm not bit of surprised that the fog light indicator didn't show up when turning on the fog lights switch. I would like for the fog lights to work if possible to work with the factory stalk.
Dec 25, 2019 at 5:46 AM
