I think someone put something in my tank
ALEECEMONI25
  • 2001 DODGE DURANGO
  • 189,950 MILES
My 01 dodge durango is new to me I had it for less than a year it was running fine until a few weeks ago and it cut off on me when I got into the parking lot of the grocery store. I was able to drive home although I heard a rattling sound from the engine. I thought that it may be due to the fact that my oil was very low. After putting oil in the car I drove around the corner where the car then shut off on me. After the car stopped I tried restarting the car while it did start the car would shut off when I pressed down on the gas peddle after that I tried to gas in the tank and I noticed that it had been tampered with. My question is this after reading this why do you think that my car shuts off when I press down on the gas peddle.
Monday, August 12th, 2013 AT 7:06 PM
  • 109,942 POSTS
That is a hard question to answer. If you think someone tampered with the fuel tank, they could have put anything in it and that could be why you are having a problem.
Since you are having trouble, if you are CONFIDENT that someone did something, I would recommend draining the fuel tank, replacing the fuel filter and cleaning out the fuel lines. Then start fresh with new fuel.
Monday, August 12th, 2013 AT 9:16 PM
