2001 Dodge Durango ENGINE QUIT
JIMAMOSES
  • 2001 DODGE DURANGO
  • V8
  • 4WD
  • 110,000 MILES
01 DODGE DURANGO SLT 4X4. ENGINE QUIT WITH NO WARNING WHILE DRIVING, LIGHTS AND GUAGES STAYED ON. STARTED RIGHT BACK UP RUNS FINE. I CHECKED ALL FLUID LEVELS, ALSO FOR LOOSE WIRES OR CONNECTIONS AND FOUND NOTHING WRONG. HELP!
Tuesday, September 14th, 2010 AT 9:33 AM
BMRFIXIT
  • 19,053 POSTS
Very common to be a bad crank position sensor
but don't over look fuel pump and do check fuel pressure and fuel flow
mark and switch ASD relay with another relay in the relay box
Crankshaft Position (CKP) Sensor (4.7L) located On right rear side of cylinder block.
Crankshaft Position (CKP) Sensor (5.9L) located On top of cylinder block, near rear of right cylinder head
Tuesday, September 14th, 2010 AT 6:16 PM
