I think my transmission is going out
180,000 MILES • V6 • 4WD • AUTOMATIC
BRETNEYLYNN
My problem started when going up hill. It would very mildly jerk while going up a hill, barely noticeable almost felt as if the gear was shifting and getting stuck. Then the other day I was driving on flat land, and it jerked really hard, like to where I had to let off the gas to almost pop it into another gear before it would get gas again.
Oct 29, 2019 at 2:50 AM
  • 110,246 POSTS
Welcome to 2CarPros.
Have you checked transmission fluid level and condition? Also, has the check engine light stayed on when the engine is running?
As far as the transmission fluid, here are the directions for checking the fluid. Do this first. Let me know the condition and color of the fluid when you check it.
2003 Mitsubishi Truck Montero V6-3.8L SOHC
Fluid Inspection
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Service and Repair Procedures Fluid Inspection
FLUID INSPECTION
TRANSMISSION FLUID CHECK
1. Drive the vehicle until the transmission fluid temperature rises to the normal temperature [70 - 80°C (158 - 176°F)].
2. Park the vehicle on a level surface.
3. Move the selector lever through all positions to fill the torque converter and the hydraulic circuits with fluid, and then move the selector lever to the "N" position.
4. After wiping off any dirt around the dipstick, remove the dipstick and check the condition of the transmission fluid.
NOTE: If the transmission fluid smells as if it is burnt, it means that the transmission fluid has been contaminated by fine particles from the bushings and friction materials. A transmission overhaul and cooler line flushing may be necessary.
pic 1
5. Check that the transmission fluid level is at the "HOT" mark on the dipstick. If the transmission fluid level is less than this, add DIAMOND ATF SPIII or equivalent transmission fluid until the level reaches the "HOT" mark.
NOTE: If the transmission fluid level is too low, the oil pump will draw in air along with the transmission fluid, which will cause bubbles to form. If the transmission fluid level is too high, rotating components inside the transmission will churn the fluid and air into a foamy liquid. Both conditions (level too low or too high) will cause the hydraulic pressure to drop, which will result in late shifting and slipping of the clutches and brakes.
In either case, air bubbles can interfere with normal valve, clutch, and brake operation. Also, foaming can cause transmission fluid to escape from the transmission vents where it may be mistaken for a leak.
6. Securely insert the dipstick.
NOTE: The transmission fluid should always be replaced under the following conditions:
^ When troubleshooting the transmission
^ When overhauling the transmission
^ When the transmission fluid is noticeably Jiffy or burnt (driving under severe conditions)
Let me know what you find.
Oct 29, 2019 at 12:27 PM
BRETNEYLYNN
My transmission fluid is fine, had my husband check yesterday while car was hot. It’s where it should be and looks exactly the color it should be. And no check engine light is not/ never has been on.
Oct 30, 2019 at 6:48 AM
  • 110,246 POSTS
Welcome back:
There are a number of things that can cause what you described. The vehicle has shift solenoids, a transmission control module, it could be related to line pressure (low) and so on. Without a check engine light, the only thing you can do is start checking things one at a time. I would most likely start with line pressure since the light never came on.
I do remember a technical service bulletin related to a delayed shift resulting from the transmission pulse sensors being switched. But that is only after work had been done.
If you want to check line pressure, let me know. I can provide you with what is needed to check.
Oct 30, 2019 at 11:37 AM
BRETNEYLYNN
Is it possible to have just gotten bad gas. I filled my tank yesterday and my car didn’t do it once since I’ve put new gas and a Lucas fuel system cleaner in.
Oct 30, 2019 at 10:03 PM
  • 110,246 POSTS
Welcome back:
Absolutely it could. Let me know if it comes back.
Oct 31, 2019 at 12:33 PM
