Shift transmission it clunks and lurches and warning lights on
120,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
BEN JACKSON
My EX model. semi auto gearbox is struggling on slow down after driving at motorway speeds. I get a warning light of a cog and then as the gearbox tries to change down it clunks and lurches. The car then stalls as it feels that it cannot change down to a stop. When I try to apply power to move off the car wont apply drive to the wheels. I have to turn off the engine and restart the car and eventually it begins to work properly. This problem only happens after motorway driving but on normal roads where the gearbox is working normally.
Mar 25, 2019 at 8:17 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Since the light is coming on, I recommend that you have the computer scanned. If there is a diagnostic trouble code related to the transmission, it will point us in the right direction.
Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
Now I realize most people don't own a scanner, but most parts stores will scan it for free. You should consider having that done,
Next, have you checked the transmission fluid condition and level? If the fluid is clean and full, this could be a pressure related issue. However, the scan would help identify that.
Check the fluid and if you can, scan the computer. Let me know what you find. Also, I'm questioning if the cog light you see is related to the traction control. Let me know what you find with the first couple checks.
Mar 26, 2019 at 10:27 AM
