After replacing MAF sensor the transmission is not shifting right at all. Do I need to reset PCM?
Aug 2, 2017 at 9:27 PM
✓Experienced Mechanic
If you replaced the MAF and now the transmission does not shift right it means the MAF is defective. I would stick to name brand replacement parts like Motorcraft and AC delco.
