I need to replace the belts on my car
200,500 MILES • 3.8L • AUTOMATIC
FRANK JAMES
I know how replace the belt for the alternator and power steering pump, but I do not know how to replace the other belt.
Aug 5, 2016 at 6:27 AM
RIVERMIKERAT
  • 6,106 POSTS
Base, Park Avenue, or T-Type?
Aug 5, 2016 at 7:44 AM
FRANK JAMES
Park avenue.
Aug 5, 2016 at 7:45 AM
RIVERMIKERAT
  • 6,106 POSTS
That should be the air conditioning compressor. Other than it being the other side of the engine, the replacement procedure is basically the same. Loosen the compressor pivot bolt and the adjuster bolt to loosen the belt. Pull the belt off. Slip the new belt on and pull on the compressor to tighten the belt. With the belt tight, tighten the adjuster bolt and then the pivot bolt.
Aug 5, 2016 at 7:57 AM
