HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Festiva
Engine
Symptoms
Not Running
New battery but car still will not start
CLCCDA
MEMBER
1989 FORD FESTIVA
1.3L
4 CYL
2WD
MANUAL
200,000 MILES
I need to replace my fusible link, but do not know where to get one. Can you help me?
Saturday, February 9th, 2019 AT 1:18 PM
MECHANIC
Good afternoon.
What makes you think it needs a fusible link? Did someone already check it for you?
Do you have a voltmeter to check the battery voltage?
SPONSORED LINKS
Saturday, February 9th, 2019 AT 1:39 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Won't Start
Again On My 89 Festiva 1.3 Efi Checked The Fuel Pump As Directed By Running A 12 Volt Hot Wire To The Pump- The Pump Worked, I Took The Fuel...
Asked by
John Fella
1989
FORD FESTIVA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1989 Ford Festiva Won't Start
I'm Trying To Figure Out Why It Isn't Getting Any Spark? It Will Turn Over Just Fine. It Had This Problem About 9,000 Miles Ago. The Guy...
Asked by
sdmacy
1 ANSWER
1989
FORD FESTIVA
Wont Start
Ok I Bought A Noid Test Kit The Light For Ford Tbi Could Not Be Plugged In As The Prongs Were 2 Far Apart So I Used The One Marked For " Geo...
Asked by
John Fella
1 ANSWER
2 IMAGES
1989
FORD FESTIVA
Wont Start
Back To My 1989 Festiva; How Do I Check The Computer Injector/s Ground Driver Circuit- As Advized And Could The Computer Causing It Not To...
Asked by
John Fella
1 ANSWER
1989
FORD FESTIVA
1989 Ford Festiva, Mazda 4cyl, Electrical Issue
The Car Runs Perfect, Shifts Perfect, Runs Perfect, And Will Start Right Up In Freezing Cold Weather With No Problem, But Every Once In...
Asked by
dogjack
1 ANSWER
1989
FORD FESTIVA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
