I need to replace my BCM
240,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DUGGH
My VIN is 1P4GP44RXVB437070.
Aug 18, 2021 at 9:00 AM
  • 110,248 POSTS
The body control module is located under the dash on the driver's side of the vehicle. I have attached the directions below for removal and replacement.
If you have other questions or need help, let me know.
Aug 18, 2021 at 9:24 AM
DUGGH
I need to order the BCM but I need to know know the part number. My VIN is 1P4GP44RXVB437070.
Aug 18, 2021 at 10:03 AM
DUGGH
I am ordering a BCM. Apparently the part number can be determined from the VIN. The VIN is:
1P4GP44RXVB437070. There are 3 possible part numbers, I would like to get the right one the first time.
Aug 19, 2021 at 3:39 AM (Merged)
Good morning,
There are 3 possibilities for the module. The VIN will not tell you the one. You need to get the number off the module in your car and match it up to the possible replacements.
https://www.2carpros.com/articles/how-to-replace-a-bcm-body-control-module
If you give me the part number on the old module, I can find you a replacement.
I attached the parts list from Alldata. There is no part number because there are several possibilities.
Aug 20, 2021 at 4:46 PM
