where I can go to purchase the transmission pawl
150,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
BACKYARD1
Every store I have check so far, does not have it.
Oct 31, 2017 at 3:59 AM
CARADIODOC
  • 34,400 POSTS
If you are referring to the parking pawl, that is not the type of part an auto parts store would stock. You can find a good used one at any transmission specialty shop or you can order it through the dealer's parts department. You can also get one at a salvage yard, but they are not going to disassemble a good transmission. They will have broken transmissions from crashed vehicles. Those go for scrap metal or are sold to re-builders. Be aware if they have to pay an employee to take the part out, they will have to charge you more for it.
Oct 31, 2017 at 9:30 AM
STEVE W.
  • 15,367 POSTS
That will not be something that the average corner parts store will have. From looking it is a part that is no longer made. I would call a couple transmission shops and see if they can get a replacement, they usually have a few donor transmissions for the odd parts.
Or if yours is broken or worn you might be able to have it welded up or even have one made at a machine shop.
Oct 31, 2017 at 9:42 AM
