I need to change ot my alternator
12,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
LETSJUSTSEE
The A.C. motor or power steering pump is above it and I just need some pictures of said in order too know. These do not show in repair manual. Thank you
Feb 13, 2016 at 7:46 AM
yes, the power steering pump needs to be removed. once it is removed the alternator will com right up. the pump is attached by a 12mm bolt and a 14 mm bolt.
Feb 14, 2016 at 12:03 AM
