I need to change my servo I think I have enough knowledge but my issue is the abs brake bleed I would like some help please?
100,000 MILES
RICKY696969
Okay, so I'm 99% sure my servo is bad i think maybe it was caused by the vacuum pump, but I can't change the vacuum to big off a job as it's behind the engine I can't and don't know how to remove an engine to do this. But I do want to remove and replace the servo and master cylinder i think I can do this alone but I just need some help with the procedure for bleeding the abs brakes I did watch your video but still a bit unsure and would appreciate some guidance I don't have the diagnostic machine and if I will need this I will need some time to buy one as I don't have any money right now hence why I'm trying to DIY it. Many thanks, Ricky. I look forward to your reply.
Jun 22, 2024 at 12:11 AM
  • 55,554 POSTS
You said, "my servo is bad" which servo? Here is the video so there is no confusion:
https://youtu.be/nQRnKyVyMuQ?si=niezXiDnMxfHromF
Please go over this video again and come back with more information and the trouble codes:
https://youtu.be/InIlnsjOVFA?si=OrshESPyJV08YerK
Please go over these guides and get back to us.
Jun 23, 2024 at 4:42 AM
