Hi guys.
I am in desperate need of the said car's electrical wiring diagram, particularly the engine management diagram. One mechanic asked for my help to start a Ford Telstar TX5 V6 that was converted from being an automatic into a manual one by fitting a manual transmission gearbox.
At present, the car the car cranks but will not fire up. It has a distributor.
There is a lot of possibilities of why it does not start, which includes TCM blocking the ECM from receiving the start permit signal since the neutral safety switch is no longer there. It could be a poorly connected ground. It could be a disconnected sensor. It could be a faulty fuel management system, compression, etc...
I am aware that all the other things can tested, which is fine. I am very worried about the engine management wiring diagram since I do not have it.
Please help with that.
Sizwe
Sizwe
Jun 8, 2024 at 8:43 AM
