Shorting oil always and too much black smoke and sometimes if you are climbing hill with speed it will slowing.
Dec 3, 2019 at 9:06 PM
AL514
✓Experienced Mechanic
Hello, how low does the oil get and how much time does it take before you have to add oil? Obviously the engine is burning oil, ie the black smoke.
Dec 3, 2019 at 9:37 PM
SAALE CULE
MEMBER
Sometimes if I go far I have to add another 2 litters of oil.
Dec 3, 2019 at 9:46 PM
AL514
That's way too much oil to be leaking out or burned, possibilities are bad valve seals, worn out piston rings, low compression . Most likely there may be internal mechanical damage. Excess oil be burned can lead to premature catalytic converter failure. Which may have already happened.
Dec 3, 2019 at 11:49 PM
If I can jump in here. this guide says a lot about the causes of black smoke:
