Engine not cranking after replacing the coil packs?
50,000 MILES • 4WD • AUTOMATIC
TANESHATHOMAS287
Yesterday my dad changed my coil packs on my vehicle. It was driving fine at first, then my uncle checked it to see what type of errors were going on with the code reader. He erased all my codes on my car. When I tried to start my car my car acted like it did not want to crank. Can someone tell me what is wrong? We checked everything. I'm so lost.
Sep 23, 2022 at 11:31 PM
  • 110,248 POSTS
Did he erase diagnostic trouble codes? That shouldn't have caused anything. When you try starting it, describe what happens. For example, let me know if it tries to start or if there is no response from the engine other than the starter engaging.
Also, if you remember the codes that he erased, let me know what they are also.
In most cases, a crank no-start condition is caused by either a loss of fuel or ignition spark. See if it will start for a couple of seconds if you use starting fluid. If it does and then stalls, we will know it is a fuel-related issue. If there is no chance, check to make sure there is spark to the plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If possible, record it cranking and upload it for me to hear. It may help me.
Let me know what you find or if you have questions.
Sep 24, 2022 at 3:28 PM
TANESHATHOMAS287
Update it's starting up and turning over but it won't stay cranked.
Sep 30, 2022 at 12:53 AM
TANESHATHOMAS287
I'm headed over today to record a video of the vehicle.
Sep 30, 2022 at 12:54 AM
  • 110,248 POSTS
Sounds good. Do you need to use starting fluid to make it start? If so, the problem is likely a fuel-related issue.
Sep 30, 2022 at 2:44 PM
