When trying to start the engine it will not start and the fuse blows
6,000 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
LARRYKELLOGG94
Every time I go to start my car It will turn the key not start it all the way and the fuse will blow. I doesn't even crank it but every time the fuse blows what can it be.
Mar 11, 2021 at 11:08 AM
  • 110,248 POSTS
It sounds like a dead short. I need to know what fuse you are referring to. Also, check the wiring near the fuse box to see if anything is damaged as far as wiring or the connectors where the fuse sits.
Here is a link for testing wiring. You may find it of interest.
Let me know if you find anything or have other questions.
Take care and God Bless,
Mar 11, 2021 at 12:02 PM
