Unfortunately, this is what is required in order to remove it because you don't have enough room to remove the bulb without removing the assembly. So to remove the assembly you need to remove the front bumper.
I attached the process from the manual to help out with this.
Here is a guide that will also help in more general terms. Let us know if you have questions. Thanks
https://www.2carpros.com/articles/turn-signal-bulb-replacement
Images (Click to enlarge)
Dec 3, 2020 at 3:34 AM
