I need a vacuum line diagram
200 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
DBM/1977
Problems idling.
Mar 12, 2021 at 10:22 AM
  • 110,251 POSTS
Often times a hard start is caused by low fuel pressure or fuel pressure drop off. Try this and see if it changes things.
1) Turn key from off to run position (engine off) and count to 5.
2) Turn key off and repeat step 1 three more times.
3) On the 4th time, see if it starts normal.
____________________
Next, have you checked for diagnostic trouble codes? This vehicle doesn't require a scan tool to get them. Follow the procedure outlined in this link:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
___________________
As far as the vacuum schematics, I attached two pics below. The first shows everything related to the EVAP system. Pic 2 simply shows the fuel pressure regulator's vacuum supply.
Take care and God Bless,
Mar 12, 2021 at 11:41 AM
