I need a ECU pinout for a FJ5A-12A650-DC?
100,000 MILES
JOSE CONTRERAS
  • 5 POSTS
I been trying to look online for the pinout but I can’t seem to find anything
Mar 16, 2026 at 4:43 PM
JOSE CONTRERAS
  • 5 POSTS
More specifically I wanna program it on bench
Mar 16, 2026 at 4:45 PM
STEVE W.
  • 15,394 POSTS
Which engine does it have? 2 or 4 WD. Need that to pull up the wiring because the current replacement ECU carries an updated part number that is used in multiple vehicles. Do you have all the gear to program it out of the vehicle? You need a computer J box and emulator as well as the correct software from Ford to be able to do anything. If you have the vehicle it is much easier to do it in it as you will also need to change files in other modules.
Mar 17, 2026 at 7:30 AM
JOSE CONTRERAS
  • 5 POSTS
I’m not sure I got it from a junkyard and yes I have all the equipment to program it I just want the pinout to make a connecter
Mar 17, 2026 at 10:53 AM
JOSE CONTRERAS
  • 5 POSTS
Is it alright if you send me both by chance?
Mar 17, 2026 at 10:56 AM
STEVE W.
  • 15,394 POSTS
There are actually more than 2 as they had a few different ECUs depending on the engine and options. I'll give you the most common ones for a 4X4 as they generally have the most connections. First batch is the 2.0 turbo part HS7Z12A650AANP layout, second batch in the next reply will be the 1.5 turbo part FV6Z12A650DANP. Notice they are different in layout.
Mar 17, 2026 at 1:29 PM
STEVE W.
  • 15,394 POSTS
And here is the second batch for the 1.5 turbo part FV6Z12A650DANP ECU Hopefully one of those will do the trick.
Mar 17, 2026 at 1:41 PM
JOSE CONTRERAS
  • 5 POSTS
Thank you
Mar 17, 2026 at 4:12 PM
STEVE W.
  • 15,394 POSTS
You are welcome.
Mar 18, 2026 at 1:12 PM
