I need a diagram for the freeze plugs
159,000 MILES • 2.3L • 4 CYL • RWD • AUTOMATIC
ANGELAHAND
We need a diagram for the freeze plugs so that I can check to see if they were bad because I change the water pump and the radiator will not hold water in it's getting hot
Apr 1, 2016 at 9:31 PM
HMAC300
  • 48,601 POSTS
have coolant system pressure checked for leaks may be a head gasket or bad radiator. we don't have pics of freeze plug locations. also check for cold spots on radiator when hot (fan disconnected) if there are any then rad is no good, should be same temp all over.
Apr 1, 2016 at 11:35 PM
