I keep blowing out my ICM Module
160,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
AT WHITS END
I was driving home from work, and car shut down. I towed it home. I found after testing The ICM failed. I replaced the module. And it started I took it for a test drive it seemed ok but while excellerating it died out and would not start. It has a new delco fuel pump and maintains 60 psi. I re tested and found again no spark further investigation I find ICM is failed again.What Could be causing the ICM's to fail?
Dec 1, 2013 at 2:41 AM
  • 110,248 POSTS
You may have gotten a bad module. Have you tried another to see if it made a difference?
Dec 1, 2013 at 3:50 AM
CJ MEDEVAC
  • 11,000 POSTS
JA PUT SOME OF THAT WHITE HEAT DISSIPATING COMPOUND ON THE BACK OF IT WHEN YOU INSTALLED IT?
THE MEDIC
Dec 1, 2013 at 8:39 AM
AT WHITS END
Yes I have Replaced it 2x and used the compound on the back both times. I did not want to change it again unless I find cause of failure. @ $70 a shot getting expensive.
Dec 3, 2013 at 1:53 AM
