After having a new clutch and fly wheel installed truck is slow to accelerate from a stop
1997 DODGE RAM
160 MILES • 5.2L • V8 • 2WD • MANUAL
SHIRLEYS
  • 25 POSTS
My truck is a very fast truck when you put it in first gear and then second gear it goes very fast. Since i had the shop put in a new clutch it dogs out, hardly no power taking off in first or second gear. i called the shop asking them if the gears are not lined up right they said it was all done right. Do you have any clues what happened to it? thanks Shirley
May 24, 2020 at 10:08 AM
If all that was changed was the clutch and fly wheel then I suspect the clutch is slipping. What happens with manual transmission and bogging down is the clutch is not fully engaged to keep the RPM in its power range so while you may not see the engine RPM drop, the power is not actually be transferred to through the transmission to the drive-train and then the wheels.
Did they replace the slave cylinder or any other components along with these? Also, did you happen to have a performance clutch in it prior and have you switch brand or used a different clutch material?
May 24, 2020 at 10:19 AM
SHIRLEYS
  • 25 POSTS
There was a new slave cylinder bought and put in. i don't know what type of clutch system that was in before. and no other clutch material were used, that i know of. i am taking it back to there shop on 5/ 27 to have them drive it. thanks, Shirley
May 24, 2020 at 6:20 PM
Okay. Let us know what they find because I am very curious with this one. Thanks for the update.
May 25, 2020 at 10:31 AM
SHIRLEYS
  • 25 POSTS
Okay, sure will.
May 25, 2020 at 11:54 AM
SHIRLEYS
  • 25 POSTS
Here is more information on truck listed above:
It is a 1500 with a 5.2 l magnum v8 mpi engine. With Laramie ALT advantage package. # 23g Clutch is a 5 speed ld. It was built for the guy i bought it from. I will let you know what i find out tomorrow.
Thanks, Shirley
May 25, 2020 at 12:53 PM
SHIRLEYS
  • 25 POSTS
I for got one thing. i had new slave cylinder clutch master cylinder put in and the clutch pedal squeaks, when i push down on the pedal. I sent this signs of a bad throw out bearing or the clutch release problems.
May 25, 2020 at 12:58 PM
You got it. Squeaking clutch is normally one of these. If it didn't do it and now it does after the clutch then something happened when they were installing it. Thanks for the update. Let me know what happens.
May 27, 2020 at 12:09 PM
SHIRLEYS
  • 25 POSTS
i will, thanks.
May 27, 2020 at 4:40 PM
