Intermittently losing power
146,831 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JAYB85
My car listed above is the GT model. It has been intermittently losing all power. I have tested my battery and my alternator and starter on a bench tester and a hand held. While still on the car voltage readings are fine. My computer has wiped all codes from its memory, but I do not have any electrical power. I have used every resource I could to find the problem. I have cleaned all my connection and replaced my ignition lock cylinder. Still the same issue. Does anyone have any suggestions?
Jul 3, 2018 at 11:08 PM
  • 55,770 POSTS
This is common when the positive battery cable goes bad. Here it a diagram to show you how to replace the cable. Make sure the terminals are clean.
Cheers, Ken
Jul 5, 2018 at 5:58 AM
