How To Use The SelfDiagnostic Function
The HVAC control unit has a selfdiagnostic function for the heating, ventilation, and air
conditioning system. To run the selfdiagnostic function, do the following:
1. Turn the ignition switch to LOCK (0), and then to ON (II).
2. Set the FAN CONTROL dial to OFF, the TEMPERATURE CONTROL dial on Max
Cool, and select the VENT mode.
3. Turn the ignition switch to LOCK (0), and then to ON (II).
4. Press and hold the RECIRCULATION CONTROL button, then within 10 seconds press
and release the REAR WINDOW DEFOGGER/MIRROR DEFOGGER button five times.
Release the RECIRCULATION CONTROL button? the recirculation indicator blinks two
times, then the selfdiagnosis begins.
1 An open in the air mix control motor circuit
2 A short in the air mix control motor circuit
3 A problem in the air mix control linkage, door, or motor circuit
4 An open in the mode control motor circuit
5 A short in the mode control motor circuit
6 A problem in the mode control linkage, doors, or motor circuit
7 An open in the recirculation control motor circuit
8 A short in the recirculation control motor circuit
9 A problem in the recirculation control linkage, door, or motor circuit
10 An open or short in the mode control circuit
11 A problem in the mode control linkage, doors, or motor circuit
12 A problem in the blower motor circuit
13 HVAC control unit internal error
14 An open in the evaporator temperature sensor circuit
15 A short in the evaporator temperature sensor circuit
Dec 17, 2020 at 3:31 AM
(Merged)
