I have to pull the back up fuse to turn off the engine
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JGRAY9617
I arked the battery off I have the wires from the ignition wired to a toggle switch and that wired to a push button. Before I arked the battery off when I would flip the toggle switch it would act as the ignition and turn all power on and all power off but since I arked the battery off when I flip it off the car continues to run until I pop the hood and pull the back up fuse.
Aug 12, 2019 at 12:31 PM
94 TRANSAM
  • 680 POSTS
Hi, thank you for using 2CarPros. I am sorry for your troubles. Lets see what we can do to resolve them.
Before we get too deep into this could you tell me what "arked the battery off" is? I am not familiar with this term and I do not want to assume and be wrong.
Thank you, Rich
Aug 12, 2019 at 2:54 PM
JGRAY9617
My ratchet grounded off between the positive and negative post on the battery.
Aug 14, 2019 at 5:01 AM
94 TRANSAM
  • 680 POSTS
Oh, I hate it when that happens. Don't feel bad, there isn't a tech out there that hasn't done that at least once.
Have you tried putting a new switch in it? The power surge may have cooked the contacts in the switch together so when you flip the toggle the contacts don't actually separate.
Rich.
Aug 14, 2019 at 10:01 AM
